Old 09-11-2009, 03:43 PM   #18 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Most everything from the rockers on up = '59, and most everything else = '89.
I'm sure it would work. Wouldn't be easy but what the hey.
I've thought about that part of it more than the 5 speed part. But that would be the icing on the cake!
Actually the 3800 a/t combo is pretty decent; I know 3800s actually are rated for higher fe than 3100s, likely due to better trans and gearing. I wonder what the potential accel and fe improvements for m/t would be? Maybe not enough to make it worth it.
You're right, given the nature of the 3800's auto, you can easily make it a manu-matic with switches and a paddle shifter, bypassing the TCU completely.
That makes it less than worth it to swap in a 5 speed if you can keep the TCL engaged all the time.
