Old 09-11-2009, 11:37 PM   #6 (permalink)
Peter7307
Originally Posted by IsaacCarlson View Post
What if i installed a momentary lockup button and just held the button on accel. and then let the converter stay locked up on its own at cruizing speed?
IsaacCarlson,
T/C lock up clutches are not designed to transmit the full torque of the engine which is why they only lock up at cruise.
A lock up clutch is around the edge of the T/C and is much smaller than a convention clutch in a manual (stick) shift gearbox.
Your lock up clutch may have a short life if you do as you are planning.
Pete.
