Old 09-12-2009, 12:37 AM   #7 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Peter7307 View Post
IsaacCarlson,
T/C lock up clutches are not designed to transmit the full torque of the engine which is why they only lock up at cruise.
A lock up clutch is around the edge of the T/C and is much smaller than a convention clutch in a manual (stick) shift gearbox.
Your lock up clutch may have a short life if you do as you are planning.
Pete.
How often have you heard of a hypermiler driving while using the full torque potential of the engine? I mean, seriously... besides that, I know several drag racers that use the TCC lock manually, and haven't smoked it yet. They're putting a lot more force against it than we are, so I think we're safe.
The Following User Says Thank You to Christ For This Useful Post:
IsaacCarlson (09-12-2009)
