Originally Posted by captainslug
The freewheel on the lower motor will have two sprockets bolted onto it using spacers. One sprocket will link the motors together, then other will drive to the rear wheel.
All that is required is to remake the motor-mount plate (to move the motors to the right a little), and drill/cut another sprocket.
So you'll have a single chain linking the two motors, then the chain from the lower motor to the rear sprocket?
