Old 09-14-2009, 08:37 PM   #64 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Wonder if you could use a slap-type shifter w/ a micro controller? Set it in a sequence to that up only goes to the next up gear, and down only goes to the next down gear using 2 single momentary contact switches to input to the controller.
Then, install a normal floor shifter assembly that will allow you to shift through the manual selections, PRND.d
