Old 03-05-2008, 08:28 PM   #2 (permalink)
s2man
I"m not lurking!
s2man's Avatar
Porthos - '96 Chevrolet Cavalier
90 day: 31.3 mpg (US)
Perhaps a metal ring behind the spoke with three (or five) drilled an tapped holes. Matching holes in your pizza pan would allow attachment with machine screws. A good fit between pizza pan and rim should keep things from shifting. Since you won't want to remove this to check your air pressure, you'll need a hole for the valve stem, and perhaps longer stems.
I've thought about using plastic, such as the bottom of a laundry basket, for caps. But I think they would deform too much from bolt mounting. Probably a better idea for someone with snap-on caps.
Roll on,
Stew
