Originally Posted by boxchain
If you get enough of them together you can slap them on your engine block and throw away your alternator. A ridiculously expensive alternator.
Ha! One of the senior design projects at my university is a thermoelectric radiator
They're just modifying an off the shelf radiator to accept the chips - the goal is 1.5kW IIRC. It's pretty cool, I usually pay attention to their presentations
But one thing I was thinking... Mount it in a wall or window in the winter and run it "backwards" to generate electricity.
It's 71 degrees outside
No use as a thermocouple
Brand is unknown - I don't want to take off the cold sink as the screws are glued in and I figure it's best to leave that alone if I want to use it at it's current performance/state
Oh, the thing - fans and all is 4 7/8" thick - 5" including the stock cool sink grille.
Those work better for heating then for cooling, as they aren't very efficient, and that wasted energy is of course turned in to heat.
Yep... Typically, I don't need any heat due to my location... But, I guess it would work as a rather inefficient dehumidifier...
