Old 09-17-2009, 03:08 AM   #330 (permalink)
SVOboy
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I'll post one tomorrow, but a quick description is this: when you remove the ignition switch there is a plastic cap on the non-soldered end that is held on with 5 clips. If you pop that (probably white) cone off you'll find inside it a little gear looking john that rests in there that's about three pieces of plastic/metal contacts stuck together. If you need to know how to take about the ignition I can tell you, but you should be able to remove the switch to get to this part by just backing out the two screws, no need to remove the actual key stuff.
