Old 09-17-2009, 10:11 PM   #17 (permalink)
dremd
EV OR DIESEL
FarFarfrumpumpen - '03 Volkswagen Jetta Wagon GLS Premium
Quorra - '12 Tesla Model S P85
Send a message via AIM to dremd
Originally Posted by jkp1187 View Post
Hard to hook up? Did he get any flack from meter readers for connecting something from the meter?
Well; the CT's (pickups) are not split, so you do have to pass the feed lines through them. which in his case required pulling the meeter to do safely (would have to do live otherwise). We called the power company; cost $100 for them to allow you (licensed electrician) to pull the meter, or if the tag is cut they charge you a $100 electricity misuse fee; however the lady told us that if the tag looks ok then they don't care. We carefully took the tag apart, did our job, and re-installed the tag no problems. if you have a disconnect/ main breaker this might not be an issue . . ..
Cliffs, have to pass feed wires through a loop may require lots of trouble.
2016 Tesla Model X
2022 Sprinter
Gone 2012 Tesla Model S P85
Gone 2013 Nissan LEAF SV
2012 Nissan LEAF SV
6 speed ALH TDI Swapped in to a 2003 Jetta Wagon
The Following User Says Thank You to dremd For This Useful Post:
jkp1187 (09-18-2009)
