Old 09-18-2009, 09:03 AM   #18 (permalink)
jkp1187
Originally Posted by dremd View Post
Well; the CT's (pickups) are not split, so you do have to pass the feed lines through them. which in his case required pulling the meeter to do safely (would have to do live otherwise). We called the power company; cost $100 for them to allow you (licensed electrician) to pull the meter, or if the tag is cut they charge you a $100 electricity misuse fee; however the lady told us that if the tag looks ok then they don't care. We carefully took the tag apart, did our job, and re-installed the tag no problems. if you have a disconnect/ main breaker this might not be an issue . . ..
Cliffs, have to pass feed wires through a loop may require lots of trouble.
Hmm. Sounds a bit more involved than I was hoping. I mean, I'm only paying a flat $0.085/kWh and I don't think there's any major power losses going on, just wanted it because I like having numbers to enter into a spreadsheet. Don't want the final price tag to crack $200, that's for sure. Would take quite a while to recoup that.
I might go with the cheaper one I listed above, it says it is not necessary to have an electrician install it....
