An simple idea : heat gaz
Hi ,
here in quebec , in winter we hit -30 degree celcius ... car milleage goes worst . But what is the différence with summer ? gaz is cold , air is cold , (engine still warn up ) ... so we can put a hot air intake but should it be possible to heat the gazoline before going to the injector or there will be condensation ?
just a simple idea ... ex: turn the line over the manifold or radiator hoses ?
