Old 09-19-2009, 10:28 PM   #233 (permalink)
Tygen1
Little Blue - '98 Ford Escort ZX2 Cool
Team ZX2
90 day: 44.75 mpg (US)
Big Red - '00 Ford Excursion XLT
90 day: 15.53 mpg (US)
I'm with ya, I can't see bending the cams, I've had mine out before and they are some beeffy units. The cam gears are steel, not stamped, more like die-cast. Theyre big and heavy. This car does have a Variable exhuast cam, I doubt the belt could damage it though....not saying it's not possible.
I've seen some pic's of ZX2's running around with about an 1/8 of a belt left. It's a very common problem. No start could be a hundred things.
You mentioned that there is no compression. Have them show you this, see it for yourself. I would be surprised if there wasn't compression. If you bent a cam, the motor probably would not turn over. So things still sound a bit fishy...
