Thread: AerocivicLB
Old 09-20-2009, 02:29 PM   #8 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by jkp1187 View Post
Meant to ask earlier - but what exactly does "lean burn" mean? (I see it mentioned a lot, but haven't seen a definition.)
My quick definition is most engines run as lean as 14.7:1 air/fuel at light load or cruise speed. Some manufacturers developed a engine that could run as lean as 22:1 air/fuel. This was done with changes made to the induction system, egr, O2 sensor, cat and ecu.
With these engines running at 22:1 air/fuel their still making the same power to the wheels that other cars make at 14.7:1 air/fuel. But they are using a lot less fuel to do it.
On my setup I changed the combustion chamber design to run as lean as 24:1air/fuel on a conventional engine(none lean burn engine) I'm using a after market EFI system, after market intake manifold, turbo, Suzuki pistons and Eagle rods to make this work. But my engine is still not considered a lean burn engine. It just runs leaner. But I keep referring to mine as lean burn based on the air fuel it runs at. So I guess I need to call it something else.
Pressure Gradient Force
The Positive Side of the Number Line
