"...NACA ducts have sloped inlets that gradually broaden...
The air molecules closest to the car move at the same speed as the car. The length and shape of the NACA duct creates counter-rotating vortices that deflect the boundary layer away from the intake, but draw in the faster-moving air above it. The NACA duct is flush with the car’s surface and doesn’t significantly disrupt the streamlines of the car."
Source: Stock Car Science: NACA Ducts
_______________________
NACA Ducts
Another source using a NACA Duct and exhaust air from a human powered streamlined vehicle. Note they never discussed using a NACA duct to remove air from the vehicle.
http://www.hupi.org/HPeJ/0002/ventilation2.pdf
NACA stands for "National Advisory Committee for Aeronautics". NACA is one of the predecessors of NASA. In the early days of aircraft design, NACA would mathematically define airfoils (example: NACA 071) and publish them in references, from which aircraft manufacturers would get specific applications
The purpose of a NACA duct is to increase the flowrate of air through it while not disturbing the boundary layer. When the cross-sectional flow area of the duct is increased, you decrease the static pressure and make the duct into a vacuum cleaner, but without the drag effects of a plain scoop. The reason why the duct is narrow, then suddenly widens in a graceful arc is to increase the cross-sectional area slowly so that airflow does separate and cause turbulence (and drag).
NACA ducts are useful when air needs to be drawn into an area which isn't exposed to the direct air flow the scoop has access to. Quite often you will see NACA ducts along the sides of a car. The NACA duct takes advantage of the Boundary layer, a layer of slow moving air that "clings" to the bodywork of the car, especially where the bodywork flattens, or does not accelerate or decelerate the air flow. Areas like the roof and side body panels are good examples. The longer the roof or body panels, the thicker the layer becomes (a source of drag that grows as the layer thickens too).
Anyway, the NACA duct scavenges this slower moving area by means of a specially shaped intake. The intake shape, shown below, drops in toward the inside of the bodywork, and this draws the slow moving air into the opening at the end of the NACA duct. Vortices are also generated by the "walls" of the duct shape, aiding in the scavenging. The shape and depth change of the duct are critical for proper operation.
