Crank could have skipped and left the cams timed to each other, but not timed correctly with the crank.
I doubt a blown head gasket would show <30PSI per cylinder, so that's probably not it. Unless you broke all four pistons, or broke/bent at least 4 out of 16 valves, it's gotta be valve timing.
