Old 03-06-2008, 04:57 PM   #12 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
if you throw a curve to the ecu and unplug a sensor how long does it take the
SG to report the glich? just for fun
i define closed loop to be when the oxygen sensor is fluctuating between .2 and .8 volts at least once per second. but the newer the engine the larger the number of sensors have to be in agreement before the ECU is truely in closed loop. as the technology got better the tolerance around .45 vdc has gotten smaller and smaller. so what is closed for a 91 engine doesn't cut it for a 2001 engine.
