Old 09-25-2009, 12:16 AM   #74 (permalink)
Jammer
Chevy and CB Radio Lover
Jammer's Avatar
Send a message via Yahoo to Jammer
Originally Posted by MadisonMPG View Post
Could someone list ALL of the differences of the regular cobalt, and the XFE?
Either the Coupe or the Sedan (which was dropped for 2010 I understand) XFE all has manual 5-Speeds, a different gear ratio (idles around 900 RPM on my tach), low resistance tires (which are quickly becoming the norm for all cars, and California is talking about passing a law forcing all new cars to come with low resistance tires because there seems to be no real down side to them) and a shift light on the dash which helps new manual transmission drivers know the best time to shift when possible. Oh, starting in 2009 the Cobalt XFE has a gas shut off at above 2,500RPM when decelerating and it is entirely impossible to detect, this change added one mile to the EPA highway rating from 36 for 2008 to 37 for 2009. Of course most of us here are getting much higher mileage.
So XFE=
#1 Low Resistance Tires,
#2 New Gear Ratio,
#3 a Shift Change light on the dash for 2009, 2010 models.
#4 For 2009 to 2010 they also added the gas cut-off upon decelerating at RPMs above 2,500 RPMs (I really can not notice it one bit).
#5: Almost forgot- XFEs have a 2.2 Liter motor, when originally the Cobalt's had a 2.0 liter engine. For whatever reason a larger engine resulting in better MPG!
#6: Manual 5-Speed Stick shift transmission. (Likely the biggest change)
These changes raised the fuel economy up about 9% based on EPA figures alone for the XFE. Honestly, unless one wants the power of the SS I feel the XFE has plenty enough power, and the Coupe has round tail lights in the rear which remind me a little bit of a Corvette. I feel the coupe looks a little like a sports car.
As far as I know that's about it. Otherwise the cars look exactly alike and come with the same standard options others (to the best of my knowledge). You can only tell them apart by looking for the rear right side badge that says "XFE". I have yet to see another Cobalt in my county that is an XFE on the roads. Although we have tons of regular Cobalts on the roads here.
If you can wait until mid-year 2010 The Lordstown Ohio plant will start building The Chevy Cruise which is rumored to replace the Cobalt and photos show a car that looks very much like the Cobalt. The Chevy Cruise is supposed to have an EPA Highway rating of over 41 MPG, maybe higher. Also the expensive Chevy plug-in electric "The Volt" shares some parts of The Cobalt and The Cruise. (Rumor has it)
Last edited by Jammer; 09-25-2009 at 04:27 PM.. Reason: Addded #5, #6, and last sentance. Fixed speeling error.
