Old 09-25-2009, 09:46 AM   #21 (permalink)
Norm-SV650
Light foot!
SV650 - '08 Suzuki SV650 SF
90 day: 70.47 mpg (US)
SKY - '07 Saturn Sky base
90 day: 42.37 mpg (US)
Corvette - '00 Chevrolet Corvette Coupe
90 day: 35.93 mpg (US)
CTS-V - '05 Cadillac CTS V-series
90 day: 31.03 mpg (US)
Allot depends on torque, lower in the rpm band the better for mpg. Something most 4 bangers don't have hence the need for EOC and PNG. I can shift at 1500 rpms in my C5 Corvette where the SV650 it's nothing below 2K rpms with light throttle.
Add a turbo to a stock 4 cylinder and you'll see more torque at lower rpms which increases mpg in most instances. If you shifted at the same 3K rpms after adding a turbo you might not even match NA.
Depending on turbo ecu, if you stay out of positive pressure or below 100 kpa, the car should be still maintaining 14.7 or stoich which would be best for mpg.
I see you have added pistons to you Sol, change in compession?
Norm
Originally Posted by pgfpro View Post
Not all of them.
If you have a management system and have your turbo map correctly you should be able to improve your FE and crush your N/A performance by a mile.
