Originally Posted by shovel
I run E85 in my s10 and my Tempo. Both have custom ECU firmware and the S10 has an updated fuel injector assembly (no more lame poppets) - running E85 in the S10 pushes me up to +24 fuel trim but that's still within range, no CEL.
They love it. There is a drop in MPG when using E85 vs. straight gasoline and a huge increase in HP. I notice no drop in MPG when using "oxygenated" gas vs. "100% gasoline" .
No fuel pump replacement yet...
Have you tried lean burn with E85? You don't even need a different oxygen sensor. Just program the firmware to lean out the mixture at constant throttle and periodically switch back to stoichiometric in order to check the ratio with the oxygen sensor.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
