If you have a ScanGauge, your instantaneous MPG display will read 9999 MPG when you're in DFCO. The 4 liter V-6 in my Mustang does it above 1500 RPM. It will do it at even lower RPM with cruise control engaged.
I use DFCO as a substitute for my service brakes whenever possible. It saves brake wear
and fuel.
