So it is a half bridge with the motor in parallel with the high side switch (FET).
Do you need a special gate driver for the high side device?
There are half bridge drivers specifically for the purpose that have the dead band built in and a high side gate driver. Just a bit concerned about forcing the high side FET on with the Source voltage going to a higher potential. Hopefully someone can tell me I am wrong
