Originally Posted by Nevyn
TEST YOUR PAINT FIRST! Some cheap spray paints like to eat through foam-plastic.
My vote is for 100% black. It'll make your car look more like the back end is floating.
Good point about the eating plastic qualities of the paint. When the time comes i'll test it on a scrap first. Isn't there an undercoat that allows the paint to flex with the plastic? I should probably consider that too.
I've also added a poll to see what the general consensus is. Obviously it won't have a bearing on mpg but it helps if the mod looks good.
ollie
