Old 10-05-2009, 10:33 AM   #2362 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by adamj12b View Post
I also cant wait to see your controller design.
-Adam
Hi Adam,
I know that you have been asking about the project that I have been working on. I attached an image of the Revolt Power PCB that I have been kicking around.
I have been using AutoCAD to figure out the mechanics of that design. My Power PCB design uses your “sandwich” technique attaching SOT227 MOSFET and Diodes to a heatsink instead of your TO247’s. Each block on the Power PCB operates at 100 amps, all are connected in parallel using a multilayer busbar.
Depending how the Power PCB assembly is populated, the options for it could be 200V@1000A or 400V@1000A with MOSFETs, or 500V@1000A with IGBTs. This Power PCB would not be cheep to build, but would offer a high end version of the ReVolt. It looks good on paper anyway !!!
