Of course you could SKIP all of this and simply place a turbine in the exhaust (turbo) attached to an alternator.
But then your not really using the wasted exhaust heat but rather the normal (not-wasted) exhaust velocity and that WILL add way more back pressure... Unless a turbo also uses heat to spin it? (although it might, I think its main source of energy is the velocity of the exhaust)
