Old 10-06-2009, 08:21 PM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by botsapper View Post
Similar to this? Here's Lemco's 2x2 installation dwg.
http://www.lmcltd.net/uploads/docume...stallation.pdf
I'm sure custom multiple motor installation brackets could be arranged.
That's the basic idea, except not using magnets/coils arranged on the outer surfaces of each rotor. Instead, you're using the outermost area of the face of each rotor, putting either magnets or coils on it, then facing it off with part of the housing that has the opposite.
If this will help you imagine it -
The rotor will go between each of the red "things" in each housing section.
Name:	rotor motor.jpg
