Originally Posted by bbraden
The older 1st generation cummins (89-93) have what is called a VE rotary pump. It is just a rotary injection pump which (relative to the new Common Rails) have a low injection pressure. These would be probably the easiest to time onto a gasoline engine. There's no electronics to fool with. These should inject PLENTY of fuel to way over-do your 300.
Also look at Benz I6 Diesels
Similar pump in my VeeDub; just electronic controls on a VE pump
There is an "M" pump for VW that is full mechanical; not that it matters (4 cylinder) but . . . .
