Old 10-08-2009, 08:03 PM   #48 (permalink)
TimJFowler
Speedster - '69 Schwinn Speedster
The guides for the sunroof are glued right to the window, so I don't have a means to remove it ATM. Ideas here would be really helpful.
Can you remove the guides (heat, solvent, careful pulling?) from the glass? If so, you could get a junkyard sunroof (just in case), remove the guides, use the glass as a cutting template and glue the guides to the new, clear lexan.
FWIW,
Tim
- Cool. Practical. Sustainable. EcoDaddyo.com -
