Old 10-08-2009, 09:16 PM   #39 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
It might.
I was getting up to 28 MPG on a full tank reading (several of them) with Granny before I gave her to my Father. We had an open element stainless mesh filter from APC, using a 45* generic aluminum intake pipe. the IAT was plugged in via a hole drilled in the intake pipe with a grommet in it, and the PCV line was just stuffed into a hole in the rubber coupler.
Even though your throttle body is probably an oval, there is an intake pipe adapter that fits perfectly. I think it's 3" against the TB. This gives great induction noise, but I can't say whether it will actually help or hurt FE. I assume it does nothing but make the car sound cool.
FWIW, 60* V6's have an annoying resonant tone in the exhaust. Get rid of that, and you're golden.
