You'll have to define O2SAT.... I can see the O2 sensor as a AFR or voltage reading.
I'm not sure the PCM will let the TCC lock at 4K, but I got a way around that
![Wink](/forum/images/smilies/wink.gif)
BTW, no MAP sensor on this car, but I got a old vacuum gauge I used to use to set the power valves on Holleys
I won't be able to do this, this weekend, but I'll get around to it.
