Old 10-09-2009, 01:49 AM   #14 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by JasonG View Post
Whoops, long day and I mistyped.
I want 2 front tires and 1 rear, 2F1R. Its the opposite off Delta its......... durn memory.
The existing engines don't matter as I'm swapping for diesel.
The diesel smart for two looks promising, cant afford to hack up anything new $$$
Tadpole, you're looking for.
That would be why you're specifically looking for a FWD drivetrain, since you want the steering capability. Of course, you can build your own project with the front suspension of said VW, and a motorcycle rear end. Make sure it's a shaft drive bike, and you can swap a small diesel and a RWD transmission into there, like the one from the Mercedes 240D, which is approximately 2/3 the length of most transmissions, with no tail shaft. If you were going with a bike transmission, you could use a belt driven bike as well.
