Old 10-09-2009, 07:49 PM   #81 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Old Mechanic View Post
My 37 Ford had a steering column lock.
Didn't know there was a car in the US where you could remove the key and not lock the column.
regards
Mech
There are some Chrysler and other cars that you can remove the key from the ignition while the engine is running.
Unless that was a seriously worn out lock cylinder...
RE: Radio locks - they're not a problem on most Fords. I don't know about other cars, but older Hondas can do it too... basically, anything that uses a 2 sided key and doesn't have a chip or resistor in the key.
The lock assembly is only moved by one side of the key. I'm not really sure why anyone made it a 2 sided key unless it was a matter of convenience, or so people would stop jamming keys in and breaking them off because they wanted to put them in upside down...
Now, have fun finding a shop that will correctly cut two keys on the same blank. I have a tooling shop that lets me cut my own keys, so I can get away with it. Not that I have any reason to do it right now.
