O O O, I can answer that. If you are using the new firmware, with no output. Set rtd-period to 100 to 500. Then leave the peddle all that way up( foot off peddle) that's your max value. Now push it all the way down to the floor. That's your min value. Now do t-max-rc ### and enter the max value you got in the first step. Then repete with min. Type save and your all set!!
Good luck.
-Adam
