Old 10-15-2009, 01:15 AM   #19 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
I've noticed a slight drop in FE (10%) when it's raining. This may be b/c then I drive in gear a little more often, less coasting, especially in traffic. But then I drove slower, and use even more engine braking.
I've also been thinking that effect of raindrops on the car. When a car is going at a constant speed and is hitting drops of rain (whose velocity vector is usually orthogonal to the car's direction of movement - I'm assuming no wind), then each of those drops gets accelerated to the car's speed. When you add up the total weight of all drops over a certain distance or time duration, it's like accelerating a large mass of water.
The Following User Says Thank You to Piwoslaw For This Useful Post:
cfg83 (10-15-2009)
