Old 03-09-2008, 02:48 PM   #40 (permalink)
edbso
Thanks for the reply and the link, most interesting.
Some thoughts.
Spray with rubberized under body coating. It is inexpensive and will cover in one application. It likely will leave a "pebbled" finish which may act as the dimples on a golf ball.
They do make stainless steel screening. Stiffer and less likely to sag.
For my Matrix an actual screen frame likely will work. It will stretch, keep the screen taught and attach with fewer attachment points. Just might be easily removable to.
I also wonder if is necessary to cover the holes.
Thanks again.
