during coast down, engine on, neutral, the engine maintains high idle to either to burn hydrocarbons(keep O2 sensors hot)(or cats) or keep the speeds in transmission matched, should i pull it back into gear. if i unplug the VSS for a test, i wonder if it will shift at all.
