Old 10-20-2009, 08:32 PM   #220 (permalink)
theunchosen
there is actually a fairly simple explanation from a design perspective for a car to have expanding girth as you get farther from the front wheels...
Space at the front of the car is usually not what the client considers useful, whereas wider rear seats, cabin or trunk space are most assuredly considered a a premium by most drivers. So if your clientele doesn't care at all how much room is availalble under the hood(and they don't) why would you spend a dime providing room? Given it is easier to have a straight line for the frame but the increased mass for longer supports to reach the mounting points for all the under bonnet components would add a substantial amount of weight as well as increase the cost. Its conveneint for the frame to be right at the edges of the motor and trans so that anything that needs to be mounted needs only to have some bolt holes instead of a strut to reach it.
But... not many passengers would be terribly comfortable or happy with the interior spaced provided with that width(my Del sol is about 3-4 inches wider at the door jam where my butt is) than where my front tires are.
So to maximize interior space and ease of manufacture under the hood the body almost automatically assumes some form of expanding shape...
