Old 10-21-2009, 03:55 PM   #34 (permalink)
Wonderboy
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
Update! I took the body down to a long time family friend's shop (he's a retired professional welder) yesterday. The shop has a fancy 5-ton crane that we used to lift the front of the car up, like so:
Using an air scaler (GREAT tool btw. - yesterday was the first time I'd even heard of one. They look like this
I went to town on the area in question, and with all the weakest spots punched out by all the vibrating needles, it ended up looking like this:
Not good. We managed to get the front control arm mount off - the threaded sleeves/nuts that were welded into that mount point up inside the hollow looked like volcanoes of rust, so we couldn't really tell if they were sleeves or nuts welded into the mount point. I got one bolt from the rear control arm bushing mount, but it was so rusty the socket started to roll over the hexagonal bolt head. The next step would've been to go inside under the pedals and torch whatever that bolt was bolted into (sleeve/nut). This is what I found when I lifted up the carpet:
I would've had to take a grinder to the floor to get to where the rear control arm bushing mount bolts into, but after looking at the floor, knowing well I'd find the same situation on the passenger side, all the labor involved with rebuilding the control arm mount point, and all of this...
Driver's side wheel well:
Pass. side strut mount:
Driver side strut mount:
...we agreed to call it quits. I decided to abandon this frame and find one where the extent of the rust is the control arm mount ONLY. I know they're out there ant not too hard to find...anyone got one lying around like that? I still have the engine. Ideally I could find a 1.3l swift with a broken motor that I could rip out and throw my engine on...probably not going to happen. I'm assuming it won't be a problem, but any issues throwing an older generation motor into a 95-01? Is there anything I should nab from the XFi before I get rid of it that are specific to the XFi (relay/fuse box? wire harness?) I noticed that the brakes are a little different on the XFi - I don't know how thick the rotor is supposed to be because it looks pretty thin (no ventillation in the middle, just one solid disc)... is it worth saving along with the calipers, which are presumably smaller and lighter than stock? If at the very least to sell or trade with someone who has a workable XFi body...
Hate to see her go. She saw nearly 1000 miles on the road with about .1 miles on her own tires from pushing her on and off the trailer Thinking about making a stencil of the XFi sticker so I can put it on the next host body for good measure.
