Old 10-21-2009, 04:14 PM   #78 (permalink)
shovel
Originally Posted by basslover911 View Post
Hi! Im sorry to bring back a little old thread BUT...
Can you put the "peel and seal" tape directly on the engine block? I want to somehow make a blanket directly on the engine block but need something that can resist the heat (probably 180 degrees or so)... I think this is the MOST effective way of keeping heat in, by directly going to the engine block instead of the hood
It'll fall off, the adhesive gets soft at high temps.
Work From Home mod has saved more fuel than everything else put together.
