Old 10-22-2009, 08:55 PM   #60 (permalink)
pgfpro
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Originally Posted by darcane View Post
A longer distance certainly would have helped....
But check your math.
IIRC, they made five trips of one mile, but they measured after each and averaged them.
At 26mpg I get:
1 mile at 26mpg = .0385 gallons.
.0385 gallons x 6.25lbs/gal = 0.241 lbs of gasoline.
.241lbs = 3.86oz or 109g
At 29mpg I get:
1 mile at 29mpg = .0345 gallons.
.0345 gallons x 6.25lbs/gal = 0.216 lbs of gasoline.
.216lbs = 3.46oz or 98g
That's certainly a measureable difference.
Your right I forgot I still had my engine settings set on a four cylinder in my spreadsheet and forgot that my numbers are fuel flow per injector.
So my figures came out to be 106grams and 96 grams with a difference of 12grams based on a specific gravity of 0.728, in which is measurable but still way to small of an amount to conclude a accurate test.
I still need to see the show. Did they do a ABA test? Because I know for fact that the fuel injection system will hold more or less fuel then 12 grams based on fuel temps alone.
Pressure Gradient Force
The Positive Side of the Number Line
