Old 10-22-2009, 11:07 PM   #36 (permalink)
Mustang Dave
Intermediate EcoDriver
Mustang Dave's Avatar
Trigger - '07 Ford Mustang V6 Premium Coupe
Team Mustang
Sports Cars
90 day: 32.76 mpg (US)
Big Red (retired) - '89 Ford F-250 4wd Custom
90 day: 18.13 mpg (US)
Big Red II - '13 Ford F-150 FX4
Pickups
90 day: 19.61 mpg (US)
Originally Posted by NiHaoMike View Post
That is true if the motor is a resistive load. But it's not. Motors draw more current to start than to run. If enough resistance is added in series, the motor will not start. Then it can draw more current than if it was running normally at full power. Obviously, that does not intentionally happen in our case. But with age, the motor bearings might tighten up such that it will fail to start on reduced current. The result is usually a blown fuse, but it's possible for the motor to be damaged by prolonged operation in "locked rotor" mode.
True. A running motor is not a purely resistive load.
A motor draws the most current when it's not turning. That goes for universal, induction, and synchronous motors. Many high-current motors use resistors in their startup circuitry to prevent excessive current draw.
As for an automotive HVAC blower motor - if it burns up, it's relatively cheap to replace.
Fuel economy is nice, but sometimes I just gotta put the spurs to my pony!
Originally Posted by thatguitarguy View Post
Just 'cuz you can't do it, don't mean it can't be done...
Originally Posted by elhigh View Post
The presence of traffic is the single most complicating factor of hypermiling. I know what I'm going to do, it's contending with whatever the hell all these other people are going to do that makes things hard.
