Thread: Project 100mpg
Old 10-23-2009, 11:45 PM   #44 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
If you're burning more oil after the change than you were before the timing belt failed, it's one of two things:
The timing belt isn't installed correctly, in which case you'd be running poorly -
Or
Damage was done when the belt gave out.
If you need a new head, you can swap on a 2.0SOHC without changing anything else.
