Old 10-24-2009, 01:30 AM   #136 (permalink)
orange4boy
orange4boy's Avatar
The Golden Egg - '93 Toyota Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Toyota Prius
90 day: 57 mpg (US)
The Spaceship - '00 Honda Insight
What the hell do you think I've got here? :P
Mole hills, my friend, mole hills. Out here cars come standard with a rate of climb indicator and an altimeter. Pressurized cabin is an option.
Hint - Industry standard is that electronics only provide ground...
If you look at injectors, shift solenoids, etc... the TCM/PCM/ECU/whatever you want to call it is always on the ground side of the circuit.
I guess Toyota didn't get the memo. Mine are 12V+ The injectors are grounded at the ECU but not the shift and TCC solenoids.
Taredog, Glad to have you on board. I can't help you with yours but you will be blazing a trail for others that do. Did you look for a kit? There are kits for some vehicles that are not too $$$ and they would come with wiring diagrams. Also, did you try any Dodge forums? Lots of guys doing it there or know how to.
