Old 10-25-2009, 10:44 PM   #21 (permalink)
Gasoline Fumes
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
Originally Posted by Christ View Post
RE: Clutch - Visit a Tractor Supply Co. store, they have centrifugal clutches. If you just want somthing simple to drive, that will do it, and they have them for like $30 that can handle 10 HP, IIRC.
You could use the governor, but engine speed control is much more likely to get you a desirable result. If you have enough gears, of course, or a CVT pulley, that will net you better results than even a throttle control would, as you could run CVT into a normal gearbox, which gives you basically Infinitely Variable ratios. (IVT).
If you don't mind using belts, and you are any good at fabrication, you can make a CVT pulley with V-belts and pulley cogs. If you want to see one, go to any place that sells MTD tractor parts, and ask them for a "transmission pulley" or CVT pulley. They call it both.
It's a double cone that slides in the middle of a wide standard pulley, which changes the open diameter on either side of the double cone. If one side is input, and the other is output, you have variable drive ratios. It's a simple "hydrostatic" transmission setup that MTD and Craftsman used to use, and may still be using.
What RPM do the centrifugal clutches engage at? I thought it was 2000+ RPM. Can the cheap ones be taken apart to replace the springs?
Thanks for the CVT pulley tip! I'll start by looking next time I'm at the junkyards. Plenty of mowers there.
How efficient are belts compared to chains or gears? I'd think belts have a lot more friction.
