Originally Posted by dwtaylorpdx
So if its such a good idea, why does a ford pickup EAT its transmission if you don't turn off the lockup when trailering? Or maybe its Lockup + overdrive? Hmm.
Never dissected this one before, all my cars have had manual transmissions,
only the company cars had autos and I didn't really care about them like my own...
Need to rent a truck and play around for a day.
Dave
Dodges do this as well. It's a combination of crappy internals
![Roll Eyes (Sarcastic)](/forum/images/smilies/rolleyes.gif)
and constant shifting between OD and high gears. Shifting means the clutches create heat due to friction and fluid shear.
I've never understood why they disable TC lock if you're not in OD, though. Makes no real sense, other than the extra weight (load) on the TCC might cause premature failure, if you're the typical driver.
I haul stuff around with 4 cylinders that most people "need" a V8 for, so I'm probably partial to non-idiocy, moreso than most.
