Old 10-29-2009, 04:41 PM   #340 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Jammer View Post
You know your a Hypermiler when you coast down a mountain side too far and too fast in EOC and your brakes go out due too too much use, you run a stop sign and nearly end up crashed off the road before you can re-start the engine.
Ah live and learn!
"Lost your brakes" as in, they overheated? Or you used them too many times and lost vacuum?
If they overheated, sure, that's a problem... if you lost vacuum, that's not a problem, you just use more pressure on the pedal... I do it all the time.
This post begs the question, of course, why were you in EOC down a mountain instead of DFCO where it would have caused less pollution (brake dust) and still not cost you any fuel?
You Know You're An EcoModder when you remember that safety always comes before hypermiling.
The Following 2 Users Say Thank You to Christ For This Useful Post:
RH77 (10-29-2009), vtec-e (11-04-2009)
