Old 10-30-2009, 01:02 AM   #41 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by basjoos View Post
I wonder what kind of mileage the Aerocivic would get with a diesel engine from the Polo
Do you have any info for the minimal BSFC of your current engine? IIRC, the 1.2L TDI was around 190g/kWh at best, so just compare that to whatever the D15Z1 is at. That said, your gearing probably isn't optimized considering how low the load must be w/ a Cd=.17 or whatever you're at, so that's where the most gains could be. Anyway, in terms of peak thermal efficiency, the lean burn engine in the Insight was the best I've seen from a production vehicle IIRC.
