Old 03-11-2008, 10:46 PM   #2 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
So there are two ways to get the car started again after you've killed it.
If you've come to a complete stop you can just start 'er up with the key like normal.
If you haven't come to a complete stop, make sure your key is in the "on" or "run" position, put the gearbox into gear (I'd reccommend using one gear higher than you would otherwise think you'll need. IE-going 20mph, I'd be in 3rd gear) Once you're in gear, slowly release the clutch pedal and the engine should fire right up.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
