If the sound moves with the tire, the tire is bad.
If the sound stays where it was, the car has an issue.
You described the noise as going away in a right turn.
Possible bad wheel bearing or CV Joint.
Both easy to fix.
Not very expensive.
I'm leaning toward wheel bearing.
Keep us posted.
BTW
Greetings,
Have Fun,
S.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
