Old 11-10-2009, 11:19 PM   #237 (permalink)
watt-a-mezz
You'd just have it on the "other" side of the controller. Between the controller and the battery pack. That's where the ForkenSwift's is.
Some of the EVDL Yodas say you really need two - one for batt amps, the other for motor amps. Because you need to know batt amps to keep from killing them, and motor amps to keep from killing it.
Thanks. I was wanting to put one in, while it is down for winter I can order another shunt and meter. Watt
