Old 11-11-2009, 06:41 PM   #24 (permalink)
aerohead
front airdam
Old Tele Man shared the paper on the Dodge Daytona Charger with me.
The front airdam on that car dropped the Cd from 0.35,to 0.29.
Even with a full bellypan you don't want air going under the car.I learned this one at Bonneville.
I'd seriously recommend that you include a front dam.It will lower drag and significantly improve stability at speed.
Also,be careful of your ground clearance and departure angle.The nose looks good clearance wise,but the center of your inter-wheel span needs a min 10-degrees,measured down to the tire/ground intersection.
You also need 10-degrees at the tail.I don't have a protractor handy,she looks kinda low.
Lastly,the state may require you to have a laminated safety glass windscreen and wiper like James Bede ran on his motorcycle/car.
Images look great!
